1961 Deck Lid drain hole questions - NCRS Discussion Boards
  • Scott P.
    • April 30, 1992
    • 178
    A 61 I am working on has the normal 4 drain holes in the deck lid trough. They seemed to be plugged so while blowing them clear I find that all 4 just empty into the area under the gas tank (which is out) and the only possible drain to the ground is the group of 3" holes under the gas tank which would be quite a ways away.
    I find nothing in the 61 AIM or the ST-12 showing or referencing these holes and where they drain to the ground.
    Are there supposed to be nipples and hoses like the trunk drains have.
    What is the original configuration of the trough drain holes.
    Thanks for your help. Scott
  • Terry D.
    • May 31, 1987
    • 2696
    Re: 1961 Deck Lid drain hole questions
    Can you post pictures?
