1982 ECM Engine Control Module - NCRS Discussion Boards
  • Josef M.
    Infrequent User
    • November 29, 2016
    • 21
    Could anyone please advice where to buy ECM for 1982 and who's got it in stock? I have searched through the websites and everywhere is unavailable...
    Thanks a lot
    Joe
  • Ken A.
    • July 31, 1986
    • 929
    Re: 1982 ECM Engine Control Module
    Corvette Central and Zip are 2 sources
    • Dick W.
      • 10483
      NAPA has one NEC XTP634 You have to use your chip.
      Dick Whittington
      • Josef M.
        Infrequent User
        • November 29, 2016
        • 21
        Thank you Ken but non of them has got it in stock. I have checked these and also Corvette America, Keen Parts, Mid America, Ecklers, Ebay, Summit Racing. Nowhere in stock...
        • Josef M.
          Infrequent User
          • November 29, 2016
          • 21
          Hi Dick, did you mean www.napaonline.com? I'm from Europe and when I go to this website access is forbidden ;-/
            • 6941
            Thanks a lot
            Joe
            Joe, what the problem with original? have you dia. the problem?
              • 43219
              Josef------
              This is an "ancient history" ECM, one of the first ECMs in use. One of the reasons for the current out-of-stock condition might be the scarcity of cores. This particular ECM, I believe GM #1225550, was used only for 1982 Corvettes, 1982 Camaros, and 1982 Firebirds.
              I think your best bet will be autoecms.com or cardone.com. If neither have the one you need in stock, then I believe that one or both of these can custom remanufacture your existing unit. Whether you can find an in-stock unit or have yours re-manufactured, it won't be cheap. Expect a minimum of $500.
