Re: 68 Big Block left side Valve Cover Grommet
Rich------
I think I may have found the explanation of the problem. The original GM #3933188 grommet had, according to GM, an ID of 31/32" (0.969"). The 1972 replacement, the GM #3894337 which remains available, has an ID, according to GM of 15/16" (0.938") (which is very close to my measurement of 0.939").
Both grommets have an OD of 1-7/16" but I believe this is measured at the very outer OD of the grommet which is a functionally irrelevent dimension. The important dimension is the OD at the surface which interfaces with the valve cover orifice. For the 3894337 it is 1.211" as I previously mentioned. I do not know what it is for the 3933188.
I expect that what occurred here is that way back in 1972 somebody at GM Service Parts Operations decided that the 3933188 and 3894337 were "close enough" in specifications that the former could be discontinued in favor of the latter. That person was wrong and that mistake has lived on for almost 50 years.
I should also mention that the folks at St. Louis never had to deal with this problem. The 3933188 was used in PRODUCTION for 1968-70 big blocks . The 3894337 was never used in PRODUCTION for any Corvette application.
For 1973-74 the grommet and connector size changed. For these years the 3989347 grommet was used for both the PCV valve as well as the PCV intake in conjunction with the smaller OD connector pipe of GM #330523.
Rich------
