1957 door and fender side moldings wahers - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    what are the OD of the flat washers and rubber washers for the t bolts that hold the body side moldings on . Door and fender .
  • Dan P.
    • December 1, 1990
    • 683
    Re: 1957 door and fender side moldings wahers
    section F sheet 2.00 57 AM 131014 flat washer is a #6 plain flat washer according to the Standard parts section
    • Dan P.
      • December 1, 1990
      • 683
      Bill Conrad was kind enough to send me pictures of his ordinal survivor 1957.Looks like a flat #6 washer and 3/4 OD rubber washer
      • David B.
        • March 1, 1980
        • 689
        # 131014 is a type A flat washer and has an average outside dimension of .375 and average thickness of .049
        The rubber washer #3723267 was designed by Chev. Engineering. Their blueprint gives the dimensions.
        • Dan P.
          • December 1, 1990
          • 683
          does anyone have the blueprint for the rubber washer .
