C2 Clock movement interchangeability - NCRS Discussion Boards
  • Ed S.
    • August 6, 2014
    • 1384
    Are all C2 clock movements (the electro-mechanical motors) the same? Will a movement from a '66 function in / fit a 64? I understand that the face of the 64 will have to be applied to the 66 motor to make it look correct. Reason I ask, I have an opportunity to purchase a functioning original 66 motor - my 64 has a quartz movement.
    Ed
  • Joe R.
    • July 31, 1976
    • 4552
    Re: C2 Clock movement interchangeability
    There are two different mechanical movements but both are interchangeable from 63-67. Only the face and the 63-64 has a different case that contains extra room for the depth of the 63-64 face. All movements are interchangeable as long as the solenoid is moved with the movement.
    JR
    • Ed S.
      • August 6, 2014
      • 1384
      Joe - thank you!
      Ed
