1963 Gas Cap Restoration Advice - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1283
    Is there an article somewhere where it shows how to restore this 1963 gas cap? I want to make sure that when I bend these tabs back, I don't ruin then and do it properly.
    Jerry
  • John D.
    • December 1, 1979
    • 5507
    Re: 1963 Gas Cap Restoration Advice
    Hi Jerry, What is wrong with you '63 fuel cap besides the plating? If that is the issue just have the cad replated. That's what I did on my '63 cap. John
    • Russ S.
      • April 30, 1982
      • 2162
      I have also had them re-plated without disassembling them.
      • Gerald C.
        • June 30, 1987
        • 1283
        John,
        Mine has a small dent in the top of the cap. Please see the pictures. Thoughts? Jerry
        • John D.
          • December 1, 1979
          • 5507
          Jerry, See the small vent hole. That's the real deal cap. But your cap does have an big dent.
          Look for another cap would be my advise Jerry. John
          • Gerald C.
            • June 30, 1987
            • 1283
            Thanks John. I'll see if I can find one at Carlisle. See you there
            • Ronald L.
              • October 18, 2009
              • 3248
              Are they the same from 63 up to? Should be lots around as many take short cut and buy new over the years.
              • Richard G.
                • July 31, 1984
                • 1715
                Like so many other things early 63's had their own gas cap.
                The newer caps fit but would be technically incorrect for a early car.
                  • 6942
                  tes the earlier cars had a dimple on the underside of cap, The location was at the vent on underside of cap. there should be a picture in the JM. I cannot quite see Jerrys cap picture is not detailed enough as I believe his car is a Oct. car.
                  • James W.
                    • December 1, 1990
                    • 2655
                    If you don't find one during your travels at Carlisle, I have an early 1963 Corvette gas cap available. Restored and has been through judging on my 1964 at a chapter meet where I found out it was for an early '63. I had it on my car because my dad bought a '63 back in 1972 and put a locking gas cap on it and put the original on the parts shelf. I restored my '64 in the early 1980's and it didn't have an Corvette gas cap but had a locking one, so down to the basement for the '63 cap. Maybe we can work out a trade plus so cash?
                    James
