63 Coupe Body Lift - Can I leave the Doors On? - NCRS Discussion Boards
  • Norm B.
    • 360
    Very soon I am going to be lifting the body off my '63 Coupe to address some frame rust issues. In researching the process I see that removing the doors is optional but I can't see a need to remove them for what I am doing. I will be using the gantry crane, lift straps, and chain fall method so weight is not a big issue. Once off the body will be put on a Noland Adams type body dolly. Since I have never done this before my question is; Is there any real advantage in removing the doors?
    Golf is for those who can't play​ hockey.
  • Dan A.
    • May 31, 1974
    • 1073
    Re: 63 Coupe Body Lift - Can I leave the Doors On?
    Yep, you sure can.
      • 11678
      The factory did it; you can too.
      • Dick W.
        • 10483
        Closed doors actually add strength to the body by tieing the A pillar to the B pillar
        Dick Whittington
        • Richard G.
          • July 31, 1984
          • 1718
          I'm sure you have a list of what to watch for or requires disconnecting.
          Seems this one it typically missing:
          When lifting the body be sure to watch the "T" handle on the transmission shift handle. It breaks easily.
          • Norm B.
            • 360
            Thanks guys. I was pretty sure I could leave them on but I wanted to make sure I was not overlooking something that might bite me later.
            • Thomas N.
              • July 31, 2002
              • 402
              If you have a rusty frame, you might have a rusty birdcage also, which the body will flex a whole lot more. What I do is make up a bar that bolts to the lower bolt of the upper hinge, and the upper bolts of the lower hinge, and bolts to the striker and ties the birdcage structure together. With this approach, you can still leave the doors on, but halfway opened. You'll get lots of responses on individual's approaches.
              NCRS New England Chapter Chairman 2022, 2024
              N E Regional Chairman 2024
              1967 Corvette Convertible Under Restoration
              1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
