French Locks vs. lock washers? - NCRS Discussion Boards
  • Rod R.
    • August 31, 1984
    • 110
    I am thinking about using a combination of lock washers and Loctite 242 instead of the French Locks on my '64 axle bolts. Is that safe? I would appreciate your thoughts.
    Rod
  • John F.
    • March 23, 2008
    • 2408
    Re: French Locks vs. lock washers?
    Why would you want to do that? How often do you pull axles? Keep it as it came from the factory!
    • Bill M.
      • 1322
      Due to the fine threads the cap screws rarely loosen up so I would stick with the original clips.
      • Rod R.
        • August 31, 1984
        • 110
        • Bill M.
          • 1322
          I was not referring to originality but safety. So then try lock washers and see if any change. But a vibration should be a bearing or a U joint. Go for a 30 minute ride and try a heat gun on all rotating parts you may find a hot spot.
          • Dick W.
            • 10483
            For short term diagnosing lock washers should be fine. Personally I am a believer in Loctite, even with the french locks. JMHO
            Dick Whittington
