Need opinion on my base engine 66 Corvette. Thanks in advance>Larry
Need opinion on Stamp Pad from Patrick Boyd or Other expert on this subject
Re: Need opinion on Stamp Pad from Patrick Boyd or Other expert on this subject
Looks good to me.- Top
I agree with Michael. That is an excellent pad with several unique characters appropriate for the 1966 time frame.- Top
Should there be broach marks on the pad? The condition of this pad is excellent, similar to my 63 and at a judging event, i received a full deduction because I didn't show any broach swirls? Just trying to learn a little bit more....- Top
Broach marks are linear, not swirls.
Not all pads show broach marks. If the blade was new, then the pad is smoother. In addition, years of aging will make them less distinct.
The theory behind the stamp pad surface deduction is to penalize the homemade "belt sander broach marks" that look very atypical, and not to deduct for the pads where they're not apparent. Unfortunately many don't realize this yet.Vice-Chairman (West), Michigan Chapter NCRS
Gerry,
If we had a better close up picture or a broach buster magnifier we might see some indications of broach marks. Some broach marks are more visible as the cutting tool wore down. Also factory broach marks are in a line and are not swirls.
Mike- Top
Broach marks are there, just very faint. As far as I am concerned anything the Master passes on is good enough to take to the bank. Small blocks, for the most part, do not have as defined broach marks as do the big blocks.Dick Whittington- Top
Sometimes broach marks are there and the pad is just not cleaned well enough. Here is the pad on my 67 before and after cleaning with Mother's Aluminum Wheel polish. The before picture is after I had cleaned the pad with lots of liquids and elbow grease. The 2nd and 3rd are after pictures with Mothers using a tooth brush and rag.Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24- Top
I am up to here with this broch mark thing. Have been machining C. I. & around machine shops for over 40 years & can say that there can be great differences in machine marks on C. I. Whether it is milled or planed or broached sharpness of the tooling, Brinell (hardness) of the iron & speed of the cutter can make a big difference in the tool marks. To me these marks are a small part of identifying a factory virgin pad. I believe it will only tell you if its not typical with nontypical machining marks under the stamping. Anyone that says that without those straight deep lines its not a factory stamp is pissing in the wind. Just my thought.65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
Picture of VIN.jpeg.pdf
I'm trying to attach a photo of my VIN pad and I get what shows above. The file is a jpeg, can anyone help me with this issue about downloading the picture?? Well, if you open this post, there is a link that has the file name with a jpeg.pdf attachment. It will ask you to open. Please do.
If I'm correct, I see some broach marks on this vin pad.
Thoughts??
ThanksLast edited by Gerald C.; July 12, 2019, 02:22 PM.- Top
In the reply tool bar there is a header that has numerous characters. On the RH side of it, third from the end, is a square with dots on all four corners. Click on that icon, chose your .jpeg, upload it from there
If you cannot get it to work, send the .jpeg to me at dick@whittingtonauction.com and I will post it for youDick Whittington- Top
Recently I was judging midyear mechanical at a Pittsburgh Chapter show. One engine pad appeared not to have any broach marks at all.
But using an I-phone photos were taken of the pad and sure enough the broach marks were there. Just not visible to the naked eye.- Top
Here it is, had to convert it to .jpg format, .pdf will not uploadAttached FilesDick Whittington- Top
