Latest info on the Differences Between St.Louis Vs. A.O. Smith C2 Bodies - NCRS Discussion Boards
  • Larry E.
    • 1680
    Question> Is there a simple "Look at the outside/inside of a C2 Corvette" without taking anything
    apart to see where the body came from exclusive of the Trim Tag?? Thanks-Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Latest info on the Differences Between St.Louis Vs. A.O. Smith C2 Bodies
    The front belt line is straighter on AO Smith while St Louis is arched. The parts are the same but the gluing fixturing is different between the two plants.
    • Harry S.
      • July 31, 2002
      • 5309
      This is from a presentation at our chapter meet. There is a great article by John Hinckley in a past Corvette Enthusiast. It's too large to post here. It's from June 2006.
      • Larry E.
        • 1680
        Thanks for the responses. Does anybody have pictures of the differences showing both bodies?? With out a reference point it is very hard to tell what is meant. Question for Gene>What do you mean by "Front Belt Line"? Thanks again-Larry
        Larry
        • Harry S.
          • July 31, 2002
          • 5309
          Larry, send me your email and I'll send you the article.
          • Larry E.
            • 1680
            Harry>I have that article that John wrote. It was a long time ago; I'm sure newer thoughts have surfaced since. Thanks-Larry
            Larry
            • Gene M.
              • April 1, 1985
              • 4232
              We have covered this quite extensively in the advanced Judges training classes at regional and National meets. Anybody interested can sign up you do not have to be a senior judge. In fact we try to cover a lot of material that is not presented in the judging guides. Owners, restorers and judges generally present in varying numbers at various meets.
              Belt line is the peak that runs all the way around the mid year body just below the bonding strip adhesive.
              • Rick A.
                • July 31, 2002
                • 2147
                Doubtful - differences are what they are and Master Hinckley spells everything out
                Rick Aleshire
                2016 Ebony C7R Z06 "ROSA"
                • John D.
                  • June 30, 1991
                  • 875
                  I was at a judging event once and the very knowledgeable judge I was with could spot the Smith cars from a distance due to the hood bulge.
                  • Michael H.
                    • December 1, 1987
                    • 730
                    Harry could you send it to me as well. PM sent with e-mail.
                    Mike
                    • Don H.
                      Moderator
                      • June 16, 2009
                      • 2262
                      Mike and all-
                      if you bing "Hinckley Other Corvette Body Builder" you will find the article in PDF.
                      here it is --->
                      A.O. Smith - The Other Corvette Body Builder.pdf
                      Mike-
                      it's also in your 3rd Qtr 2013 StL Chapter Newsletter. But, that has been a while ago now....
                      • Michael H.
                        • December 1, 1987
                        • 730
                        Originally posted by Don Hooper (50543)
                        Mike and all-
                        here it is --->
                        [ATTACH]92850[/ATTACH]
                        Thank you Don and Harry, great article.
                        Mike
                        • Harry S.
                          • July 31, 2002
                          • 5309
                          Don, I see your PDF is 4 meg smaller than mine, so attaching it worked for you. Mine has the magazine cover included.
                          • Larry E.
                            • 1680
                            Just as I thought there is no easy way to tell the difference unless your a Master Judge. Without pictures showing the difference all
                            the points mentioned are completely useless to the average Corvette fan. JMHO Thanks for responses-Larry
                            Larry
                            • Don H.
                              Moderator
                              • June 16, 2009
                              • 2262
                              I imagine that is exactly how Chevrolet wanted it.
