Correct dipstick 1968 427/390
Re: Correct dipstick 1968 427/390
George------
6 quarts is correct for all 1965-74 Corvette big blocks assuming the car has the correct oil pan. The correct oil pan has a REAR drain plug. Most other Chevrolet big blocks used a SIDE drain plug. These sometimes end up on Corvettes. It's easy to check.
Correct dipstick should have a white plug on the end of the handle. Otherwise, does the dipstick have a part number embossed on it (on the lower part of the blade)?In Appreciation of John Hinckley- Top
- Top
- Top
Okay,
It seems that I have the correct dipstick ( the ADD mark is apx. 1 1/2" from the bottom tip of the dipstick)
Reads a full quart over full.
Could the tube be too short?
Does anyone have a measurement for the tube?
G- Top
George,
Without pulling the tube from the pan, I have right at 12 & 3/4" from the pan tube lip to the top of the tube . Probably another 1" or a bit more inserted into the pan tube for a total length of approx 14".
Ray- Top
Ray and George------
As you know, the important dimension is that from the upper end to the collar which seats on the oil pan's extension tube. The 1965-E67 GM #3862732 and L1967-E1970 GM #3870324 were as mentioned 12-3/4". The late 1970-74 tube, GM #3981089, was 19-17/32" developed length from upper end to collar. These are the only tubes ever used for any 1965-74 Corvette. Any other length tube is incorrect. In addition, the correct dipsticks have to be used with correct tubes in order for the dipstick reading to be accurate.
The GM #3862732 or 3870324 tubes must be used with dipsticks GM #3860316, 3925520, or 3959158
The GM #3981089 tube must be used with dipstick GM #3981088.
George: if you have the correct dipstick and correct tube and you are still getting an inaccurate dipstick reading, then I would say one of three problems are involved:
1) you do not have the dipstick tube fully seated in the oil pan's extension tube, or;
2) you do not have the dipstick fully seated on the tube, or;
3) you have an incorrect oil pan.In Appreciation of John Hinckley- Top
