National Convention - Greenville Convention Center, Locations - NCRS Discussion Boards
  • Bob K.
    • March 3, 2013
    • 145
    The attached attachment shows location of events around the Greenville Convention Center.
    If you are heading to registration without a trailer you should use a GPS adders of 1 Exposition Drive
    If you are towing a trailer with a car for judging you should us a GPS address of 58 Watson Aviation Road
    Bob
  • Tom D.
    • September 30, 1981
    • 2128
    Re: National Convention - Greenville Convention Center, Locations
    Should this be a "sticky" post?
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Don H.
      • December 1, 1981
      • 1483
      This appears to be the same map (but different name) that was posted under the "sticky" above titled:
      Re: 2019 National Convention, Greenville – Trailer parking
      • Steve B.
        • July 31, 2002
        • 51
        Is there a designated are for larger carriers, like Reliable, to unload cars? Or should they use the 58 Watson aviation road address as well?
        1994 ZR1 Green / Beige
        2009 Cyber Gray / Red Coupe
        • Bob K.
          • March 3, 2013
          • 145
          use the Watson Aviation road address. However call me 864 346 6126 There is a map of the site I attached to an earlier post. i would like opinion for someone driving an 18 wheeler to see where is the best place, as we have been having discussions. Those that are unloading and staying is one place but what to do with the ones unloading and leaving is another.
          • Steve B.
            • July 31, 2002
            • 51
            Hi Bob. Reliable Carriers can probably answer that question better than I can. I recommend contacting Bob Sellers there at bsellers@reliablecarriers.com or 800-521-6393 x 6262.
