C-2 Ash Tray - NCRS Discussion Boards
C-2 Ash Tray
  • Robert C.
    • December 1, 2001
    • 46
    C-2 Ash Tray
    I recently replaced the boot in the consol of my 65 coupe. Everything seemed to go together fine but I can't get the ash tray in deep enough for the slide door to close. It feels like the ash tray isn't dropping down far enough. I've tried putting a new one in and the old one. Neither fit. Any thoughts appreciated.
  • Gene M.
    • April 1, 1985
    • 4233
    Re: C-2 Ash Tray
    Assuming the reproduction boot is the cause?
    Is it too shallow?
    • Robert C.
      • December 1, 2001
      • 46
      Re: C-2 Ash Tray
      It definitely seems like it.
      • Don H.
        • December 1, 1981
        • 1501
        Re: C-2 Ash Tray
        Do you still have the previous one to compare dimensions?
        • Robert C.
          • December 1, 2001
          • 46
          Re: C-2 Ash Tray
          Yes they seem to be the same.
          • Robert C.
            • December 1, 2001
            • 46
            Re: C-2 Ash Tray
            Correction I still have the ash tray unfortunately the original boot was so bad it basically feel apart and was thrown away.
            • Bill M.
              • 1330
              Re: C-2 Ash Tray
              Is there an air bubble between the body and the rubber?
              • Robert C.
                • December 1, 2001
                • 46
                Re: C-2 Ash Tray
                There doesn't appear to be.
                • Stephen L.
                  • May 31, 1984
                  • 3163
                  • Richard G.
                    • July 31, 1984
                    • 1718
                    Re: C-2 Ash Tray
                    I would double check the boot thickness. Someone has to have an original they will measure for you.
                    Then compare it to the one you have.
                    Not too long ago there was a post here and the members bypass hose clamps didn't fit the hose.
                    Traced it to a reproduction hose that was much thinner than the original.
                    Could be?
                    Best of luck
                    Rick
                    • Dan T.
                      • March 1, 1979
                      • 42
                      Re: C-2 Ash Tray
                      Try a little WD-40 to help push it down inside the rubber.
