Corvette 1963 car #34 body tag question - NCRS Discussion Boards
  • Earl R.
    • June 12, 2019
    • 11
    Re: Corvette 1963 car #34 body tag question
    With my body Tag A1, would be either August 1st week under system #1 (early) and then system #2 (production started) A1 would be Sept 1st week. But given such a low body number, it would have to be August 1st week. But the Vin is a little high, but when I took the frame off to be sand blasted and painted, and checked the bird cage, its an original body to the bird cage and rest of the car.
    Plus the car had a shipping date of June 5th
    so how did a high vin number get a low body number ????
    • Larry G.
      Infrequent User
      • October 4, 2017
      • 17
      Originally posted by Earl Rodrigue (65980)
      I have corvette #34 and noticed the body tag has no build date code. I have check some pilot line body tags, and they do not have a build date either. Is it posable the a pilot line convertible body was build but never installed, as the coupe was the most desired, and they put this pilot line body on the car when production started.
      My build date is Sept 5th 1962 with body #13
      Dealler zone code 000-00 which means it went to GM for internal projects.
      Also found a tag on the rear drivers side frame saying "Lab Frame 70"
      Just seeing if anyone knew of extra bodies built but never installed durng the pilot line phase.
      There was no 1963 Model Pilot Line. There were a few, about 6, pre production jobs that were built in Flint or elsewhere but not St. Louis.
      There were no bodies built in St. Louis that were not married to a chassis.
      I have no proof concerning the "Lab Frame 70" tag. However, I can attest to the following. Before A. O. Smith Granite City, Illinois received a release to produce the frame in quantity, a full dimensional inspection was required and approved by Chevrolet Central Office Quality Control. (I worked there in 1964 thru 1969) Chevrolet Central Office Quality Control did not have a surface plate large enough to inspect the finished frame. Chevrolet St. Louis did have a surface plate large enough to lay out (dimensionally inspect) a finished Corvette body at that time. The process for the approval of a finished frame allowing A. O. Smith to ship frames could have been accomplished by A. O. Smith laying out the frame witnessed by a Chevrolet Quality Engineer (I did this on other parts). The frame(s) so tagged could have easily been identified with the "Lab Frame" tag.
      • Earl R.
        • June 12, 2019
        • 11
        #18
        Thanks for your input.
        Earl
        • Earl R.
          • June 12, 2019
          • 11
          #19
          Re: I'm a little out of touch, but...
          Ebay listing with pictures
          • James G.
            • May 31, 1976
            • 1556
            #20
            Interesting add. I sent it to FRANZ and other 63 collectors.
            • Earl R.
              • June 12, 2019
              • 11
              #21
              Thanks for the help, much appreciated
              • Dan A.
                • May 31, 1974
                • 1073
                #22
                Is this car registered in Quebec with a Quebec vehicle registration colloquially called an ownership in English Canada?
                • Earl R.
                  • June 12, 2019
                  • 11
                  #23
                  Yes, its called a "registration "
                  And it passed the Quebec inspection 2 years ago. very hard to pass a Quebec inspection, they look at everything, right down to the washer squirter.
