Re: 67 L71 Carburetor temparture
You aren't kidding they get hot. Is that a standard carb base gasket or a phonelic spacer? I've installed phonelic spacers on mine and it helped a bit but nothing to write home about. I don't know what's going on with my car. Except for blocking off the heat risers like you did, I've tried all of the suggestions on the board and more. Although I did make a little headway yesterday when I adjusted the float levels. Thank you for your information. It's very much appreciated.
