15-40 Rotella versus Straight 40 - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4602
    Re: 15-40 Rotella versus Straight 40
    I guess I'm living a charmed life. My Mobil 1 fed LS5 only had two leak issues: Valve covers (which I finally conquered) and the oil drain plug (which tend to leak on Chevys with any type of oil).
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Dick W.
      • 10483
      LS engines are normally as dry as a "dust fart". They were designed for synthetic oils
      Dick Whittington
        • 11669
        #18
        They will leak at the drain plug if you don't replace that rubber gasket/insert with each oil change.
        Ask how I know.
          • 43248
          #19
          Ask how I know.
          Patrick------
          I replace it (GM #14090908) every oil change and they still leak.
          • Dick W.
            • 10483
            #20
            Ask how I know.
            I use Loctite PST on the oil pan drain plug threads and stop the leaks. Our Yukon has 100,000 miles on it and not even a damp spot anywhere.
            Dick Whittington
              • 43248
              #21
              Dick-------
              I've tried that, too, after I scrupulously cleaned the threads in the pan and on the plug. Didn't work for me.
              • James G.
                • May 31, 1976
                • 1556
                #22
                The only Corvette I have owned that does NOT leak is my current 96 LT-1. Every C-1 and C-2 leaked oil.
                • Mark E.
                  • April 1, 1993
                  • 4602
                  #23
                  Dick,
                  To clarify, I have an LS5 454 which is a first gen big block, not an LS engine.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
