Re: back firing 340 hp
Is it actually "back firing" through the carburetor - popping back or is it more of an ignition miss fire? The only way, as far as I am aware that you will get detonation back through the intake manifold and up the carb is if one or more intake valves are partially or completely open. Bucking or "missing" ignition spark will cause some popping sound but not back through the carb. If you really are getting explosions back through the carb an intake valve must be open (or the timing is so far off it is ridiculous - but you would likely not even be able to start the engine no less wind it up to 5000 + RPM). Do you have stock valve springs or do you have some after market dual spring setup? Weak or worn springs will allow the valves to float some at higher RPM - in this case you would get that popping back through the carb. I ask if you have a dual spring set up - if you do and one spring on one valve is broken it will run fine at lower RPM - but fail to close the valve fast enough at higher rev ranges.
