L76 340HP Idler nut and washer finish. - NCRS Discussion Boards
  • Richard G.
    • July 31, 1984
    • 1718
    I just replaced my water pump on my 63.
    When I installed the Idler Pulley Assembly the nut, lock-washer and flat washer didn't look correct so I changed them out to black oxide from Zinc. I have no idea which is correct as it isn't mentioned in the JM. The JM did identify the long hex stud finish as black oxide or black phosphate.
    Below are the part numbers out of the assemble manual.
    120377 Nut
    446212 P washer
    120382 L washer
    Can anyone identify the correct finish for me?
    Rick
    • 43259
    Re: L76 340HP Idler nut and washer finish.
    120377 Nut
    446212 P washer
    120382 L washer
    Rick
    Rick------
    120377 Nut---------zinc
    446212 P washer----zinc
    120382 L washer-----zinc
    • Richard G.
      • July 31, 1984
      • 1718
      Thanks Joe!
      I will return it to the way I had it.
      I am going to make a note in my AM also.
      Rick
