Goodyear vs. Firestone?
Re: Goodyear vs. Firestone?
If Firestone was not an OEM tire for that year vette, then Firestones would take a deduction in judging. Check the Standard Deduction Guidelines for tires to see how much that deduction would be. Even if there would be a deduction, if you work for Firestone, and you want to run Firestones on your car, you should do so, and don't be concerned how they would fare in judging. In the big scheme of things, does say a 30 point deduction out of 4510 possible points in flight judging make that big of a difference? It wouldn't to me.- Top
You're in luck, according to the TIM&JG, '73s came with Goodyear and Firestone, Steel Radial 500, tires.Big Tanks In the High Mountains of New Mexico- Top
Robert------i know this is a bias ply Goodyear. The car was made October 72. I have not pulled the tank sticker to find out exactly what was on it. I guess it could have had the recalled Firestone’s and just had Goodyear’s put on it. The spare appears to the original as the car has 35000 miles on it.
I have no knowledge of any 1973's having been originally equipped with bias ply tires. The style tire you picture was last used for the 1972 model year and, to my knowledge, there was no "carry-over" into 1973. Among other reasons, 1973's were advertised as having radial tires.In Appreciation of John Hinckley- Top
Robert------
Maybe some previous owner needed a spare tire and got one from another Corvette way before the value of these things went through the roof. Only Corvettes used these model tires.In Appreciation of John Hinckley- Top
Check the DOT code on the tire, and the date code on the rim.Vice-Chairman (West), Michigan Chapter NCRS
There will be deductions, depending on the construction and size of the tire you mount as it deviates from originals. Since the originals were radials, you can mount a Firestone radial. You would get a 60% deduction for current day replacement OEM brand tires, as long as the sizing and sidewall is like original. But if you had a non-Firestone or Goodyear, the deduction would be 75%. All the details are in the Standard Deduction Guidelines in the Judging Guide.Big Tanks In the High Mountains of New Mexico- Top
Patrick I definitely will check the dot date codes and rim date codes for sure. The car will be delivered early next week. My brother James went to look at the car for me. He has an original paint 1971 brands Hatch green LT-1. I am going to carefully clean and document everything on this car.- Top
I met your brother and judged his car in Cincinnati last month.Patrick I definitely will check the dot date codes and rim date codes for sure. The car will be delivered early next week. My brother James went to look at the car for me. He has an original paint 1971 brands Hatch green LT-1. I am going to carefully clean and document everything on this car.Vice-Chairman (West), Michigan Chapter NCRS
