1970 ZR1 pump has 68 date? - NCRS Discussion Boards
  • Ronald R.
    • May 31, 1989
    • 670
    my water pump has a 68 date 608 and suppose to be orig?? amy help appreciated thanks Ronnie
  • James G.
    • August 22, 2018
    • 800
    Re: 1970 ZR1 pump has 68 date?
    What exactly is the date code?
    In it's alpha numeric format...
    James A Groome
    1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
    1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
    My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
    Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
    • Ronald R.
      • May 31, 1989
      • 670
      K208 3782608
      • Mike E.
        • February 28, 1975
        • 5138
        The 608 is the most common Chevy small-block pump there is. You go to a chain store today to get a pump for 68-70, and your chances are really good that they will have a rebuilt 608 in a box. I would say that is how/where that pump got on your car rather than installed at the factory. October 68 to your car in 1970 is an extraordinarily long gap for the factory.
          • 43219
          Ronnie-------
          As others have said, it's highly unlikely to be original. However, are you sure the last character is an "8" and not a "9"?
          Another thing: how many miles are on the car?
          • Ron G.
            • December 1, 1984
            • 865
            Just to add what Joe says. There should be no difference in a regular production LT-1 fuel pump versus one on a ZR-1.
            "SOLID LIFTERS MATTER"
            • Ronald R.
              • May 31, 1989
              • 670
              This is a 20k mile ZR1 with only one owner before me that drove the car.
              thanks RDR
                • 43219
                thanks RDR
                Ronald----
                At that mileage the pump could be original if the date is actually 1969 and not 1968. These 5/8" shaft pumps are generally good for about 50,000 miles, max.
                • Ronald R.
                  • May 31, 1989
                  • 670
                  Thank for the info, My brother started the resto on this car years back and was killed in a motorcycle accident. I'm not sure if he kept the original so i quess I am on the hunt. I have found one that was dated a month after my car so dont think the judges will go for this. thans Ronnie
