Wheels-what do I have? - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 829
    The codes on my wheels are K31 then 8 with a 18 and YA on the other side. Can someone tell me what they are? Came off my 65.
    • 43290
    Re: Wheels-what do I have?
    Bob------
    The only "YA" coded wheels I have record of are 14 X 7 wheels used for some 1969-70 Camaros, Chevelles, and Chevy II. Are your wheels 14"? I would not think that 14" wheels would fit on a Corvette with disc brakes.
    • Bob H.
      • July 31, 2000
      • 829
      Sorry for the delay and thanks for the response. They are indeed 15"
        • 43290
        Bob------
        In that case, I don't know what they are. The only "YA" coded wheels I can find are the 14" I mentioned.
        • Bob H.
          • July 31, 2000
          • 829
          What kind of code would be typical?
            • 43290
            Bob------
            I don't know of any codes on 1965 wheels.
            • Gary B.
              • February 1, 1997
              • 7082
              Don't the '65 and '66 steel wheels have a stamping on the inside that says something like
              15 X 5 1/2 JK?
              Gary
                • 43290
                15 X 5 1/2 JK?
                Gary
                Gary------
                Yes, it should have that if they're original. However, "JK" is not a specific wheel code. It was used on many different wheels. It denotes the rim configuration of the wheel.
                • John L.
                  • February 20, 2009
                  • 186
                  • Gary B.
                    • February 1, 1997
                    • 7082
                    John,
                    When you say the "type already mentioned", do you mean the YA type of the JK type?
                    Gary
                    • John L.
                      • February 20, 2009
                      • 186
                      • Gary B.
                        • February 1, 1997
                        • 7082
                        John,
                        That's the stamping that all '65 and' 66 Kelsey Hayes steel should have. Along with a date code.
                        It's the YA stamping that Bob has that is unknown.
                        Gary
                        • Dan A.
                          • May 31, 1974
                          • 1073
                          I'm going to guess the YA you speak of follows the date you mention and starts on one side of the valve stem hole and ends on the other. Am I correct?
                          • Bob H.
                            • July 31, 2000
                            • 829
                            • David L.
                              • July 31, 1980
                              • 3310
                              Bob,
                              I have to agree with Joe L.
                              The stampings can be decoded as follows:
                              "K31"
                              K = Kelsey-Hayes, the manufacturer
                              3 = Philadelphia, PA
                              1 = 1971
                              8 = August
                              18 = 18th day of the month
                              "YA" = code for 14" X 7"
                              This wheel is listed for 1970 Chevelle SS models in the "1970-75 by the Numbers" by Alan L. Colvin as well as 1969 Camaro SS and Nova models in "1965-69 Chevrolet by the numbers".
                              Somewhere on the wheel there should be a stamping indication the size (examples "14 X 7", "14 X 7 JJ", "14 X 6 JK", "15 X 7 JJ").
                              Is you Corvette an "early" 1965? As best as I can remember I think that "early" 1965's came with drum brakes.
                              If this is a 14" X 7" wheel the GROSS outside diameter of the wheel should measure about 15" and the GROSS width should measure about 8".
                              A 15" X 7" wheel will measure about 16" (GROSS outside diameter) and about 8" (GROSS width).
                              If your wheel is truly a 15" wheel I will be totally baffled.......or......it could be an error when the wheel was stamped.
                              There is a 1969 Camaro "YA" rally wheel (14" X 7") dated Dec. 10, 1968, currently on Ebay (clicked on Ebay item number below).
                              Dave
                              122937595685
