Question pertains to a '64. Has anyone ever removed an original bulb socket and wire harness assembly from a parking lamp housing and replaced it with an Electric Limited wiring harness repair kit?
It seems easy enough to remove the original socket from the chrome housing - the issue or concern I have is installing the replacement from Electric Limited and getting the prongs bent down tight enough so there is not movement of the socket.
Is there a trick to or a caution regarding the installation of the replacement harness? Picture of my original with red arrow pointing toward the pressed ring that secures the socket into the housing - just bending up the ring will allow the socket to be removed.
Also attached is a pic of the Electric Limited repair harness - how to get those prongs bent over tight?
For what it is worth, I have searched this forum as best I can for tips on this issue - found none.
