1969 carpet underlay/jute padding question - NCRS Discussion Boards
  • Paul S.
    • October 29, 2015
    • 203
    Hi all,
    I recently removed the reproduction carpet from my '69 convertible, and underneath it, I found what I suspect to be some original carpet underlay still glued to the floor in the front of the car:
    It's got some over-spray on it from when a previous owner repainted the car, but it is yellow/brown padding with a black rubber-ish layer on top. Two questions:
    1. Is this original?
    2. Is this all the jute padding that was under the front carpet originally, or does more go on top of this? I ask because the reproduction carpet I removed had a thicker layer of gray jute padding attached to it across the entire bottom.
    Thanks in advance for any help,
    Paul
    • 11692
    Re: 1969 carpet underlay/jute padding question
    1. Yes.
    2. Yes, that's what there was, though I have also seen another layer of "very thick roofing paper" underneath what you see there. I have not seen a pattern for it. As you can see, the reproduction stuff is entirely different.
    I kept this underlayment from a 1970 that I worked on just so I can use it as a pattern for future carpet replacements.
