1970 ZR1 paint - NCRS Discussion Boards
1970 ZR1 paint
  • Ronald R.
    • May 31, 1989
    • 670
    1970 ZR1 paint
    Ready to paint the old car white and can't get good match here. Can anyone recommend a supplier for white? Also best way to get hood stripes installed?? thanks Ronnie
  • Gary C.
    Administrator
    • October 1, 1982
    • 17693
    Re: 1970 ZR1 paint
    Ronnie,
    Suggest you contact Tom Ames. Tom can be found in the Member's list.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Ronald R.
      • May 31, 1989
      • 670
      Re: 1970 ZR1 paint
      thanks for the help.
      • Leonard M.
        • September 7, 2009
        • 236
        Re: 1970 ZR1 paint
        This may be worth an inquiry.
        • James G.
          • August 22, 2018
          • 800
          Re: 1970 ZR1 paint
          No doubt. Code 10 white a gallon for $50... CHEAP.
          That ASIDE I will attest to the Help provided by John Ballard, I recently repaired the front wheel lips, corrected some gaps, and fixed a few stress cracks a 71 Warbonnet Roadster and his help with the color match was invaluable. (I provided him with the mix formula in chroma)
          James A Groome
          • Dick W.
            • 10483
            Re: 1970 ZR1 paint
            You can tint the paint to match your original. Years ago, when I was still painting, most paints, unless you got a factory pack, would have to be tinted to match. Some of the factory packs were not a perfect match
            Dick Whittington
            • James G.
              • August 22, 2018
              • 800
              Re: 1970 ZR1 paint
              Hood stripes... if the car has the variable stripe in NEEDS TO BE DONE CORRECTLY for the car to have the right appearance., WRONG LT1 stripes are a pet peeve of mine... IMHO any wrong stripe just kills the look of a factory original restoration.
              The thick thin stripe is unique and you should question whomever is going to apply it and make sure they understand the difference.
              James A Groome
