1972 POA valve removal - Ideas?? - NCRS Discussion Boards
  • Gary J.
    • April 1, 1980
    • 1246
    I have the task of removing a POA valve from a 1972 Corvette. Any Ideas? Does NOT look like fun. Just looking for some ideas from someone who has been there, done that. Thanks.
  • Dick W.
    • 10483
    Re: 1972 POA valve removal - Ideas??
    Need a good set of angle wrenches, plenty of a good penetrating oil, and a large dose of patience.
    Dick Whittington
    • Mark E.
      • April 1, 1993
      • 4607
      First, you're lucky you have a 70-72 with removable gills. That gives better work access.
      Try what Dick suggested to unscrew the POA from the evaporator and low pressure line. Unfortunately, if more than a few years since installation, these fittings are often hopelessly frozen due to corrosion from condensation. I've seen heat used with some success but that's risky in the engine compartment.
      I ended up cutting the low pressure line, then removing the evaporator and POA from the car as an assembly. After removal I still wasn't able to break loose the POA from the evaporator. That wasn't an issue since both components were replaced anyway.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Jeffrey S.
        • May 31, 1988
        • 1898
        I found that the most difficult fastener to remove and replace on my '69 was the one at the bottom of the POA. I removed the splash shields (triangular steel plates with rubber on the edge) and used a crow foot wrench that attaches to my socket handle with extension. Made the job much easier.
        Jeff
