C2 Front Bumper Bolt Spacer Finish - NCRS Discussion Boards
  • Ed S.
    • August 6, 2014
    • 1388
    What is the correct finish for the front bumper bolt spacers? I assume all C2s use the same spacer but if not, my question pertains to a '64.
    I am talking about the spacers that go on the long brackets that are mounted to the front cross member. The bumper assembly requires 4 of these.
    One "vendor" shows the spacers as black, another shows them as bright bare metal - possibly zinc plated, possibly natural.
    Are they painted, black phosphorous, zinc or whatever?
    Ed
  • Ed S.
    • August 6, 2014
    • 1388
    Re: C2 Front Bumper Bolt Spacer Finish
    Disregard ---- I found the answer - it was in a forum thread. The consensus is the spacers are black or black phosphorous.
    Here is the link to the thread: https://www.forums.ncrs.org/showthre...racket-spacers
    Ed
    • Richard G.
      • July 31, 1984
      • 1718
      Ed.
      Thanks for the link.
      Some good information there. It is easy to forget the details.
      Like this information from the link;
      And, counter-intuitively, the nuts go on the outboard ends of the bolts.
      I would like to know the length of the spacers. I was having a terrible time getting mine in and I read where the aftermarket spacers can be an incorrect length. I would like to confirm mine are correct.
      Rick
      • Mike M.
        • May 31, 1974
        • 8408
        i've had to shorten the length of repos. simple put them in a vice and got the grinder out. mike
        • Ed S.
          • August 6, 2014
          • 1388
          I will be ordering from LIC - their's are "black" - not sure what the finish actually is but at least they aren't shiny. As for length, I suspect that I will have to "adjust" the length of them to make them fit. My '64 does not have the spacers and I am sure that the PO collapsed the channel brackets some when he tightened them. I will put up another post with the length of the new ones when I get them.
          Ed
          • Edward D.
            • October 25, 2014
            • 206
            To add a bit to all the above advice, the spacers should be a fairly tight fit inside the bumper channels. You can grind some off of an end of them if the channels have been collapsed in a bit, but before you do so check that the bumper channels fit well into the brace channels. You may need to expand bumper channels or compress brace channels for a decent fit. Lastly the spacers usually fit tight and have to be helped into place with a plastic mallet and a drift pin thru the entire assy before you can get the bolt thru.
