CE Engine Stamp Prefix - NCRS Discussion Boards
  • Dan A.
    • May 31, 1974
    • 1073
    Re: CE Engine Stamp Prefix
    1 All the numbers that are pertinent to understanding what the block started out as are, the casting number. Which you have only touched on in a vague sense. We need specifics. The casting date is essential as well. You have provided the stamping from the pad. So only two more essential numbers remain.
    2 The CE stamping adds to the case for a deduction as it gives a year other than 66-7. That information at this point is good for having a better understanding of what the block is. But the casting numbers are judged before anything on the stamp pad as Page has said.
    3 CE and what it means- there are a number of discussions in the archives. John Hinckley explained the CE & CT program, it's duration and how to interpret the stamp. Search John Hinckley CE. The CE program is also covered in an actual Chevrolet document. There is a Chevrolet TSB (Technical Service Bulletin) which was distributed to all Dealers announcing and explained the program to those in the field.
    4 I'm sensing from your posts that your under the impression the CE blocks were warranty replacements only. CE engines were a service part. Meaning they were sold through the dealer parts department. Or over the counter as they say. The majority of CE program blocks and engines were sold retail/wholesale rather than warrantied. GM has never been too quick to warranty a fitted block, short block, long block or complete engine under warranty. Most dealers would have required DSM (District Service Manager ) approval first in order to be paid under warranty.
    5 You are correct, CE stands for Chevrolet engine. This is explained in John Hinckley's post and the Chevrolet TSB. Some have applied names like Counter Engine and others, they are urban myth or old wives tales. Also part of the program were CT's as in Chevrolet Transmission. OE, PE, BT meaning Oldsmobile Engine, Pontiac Engine, Buick Transmission and so on.
    6 What's the difference between a CE block and a service block? The short answer is no difference other than the CE was a program that ran from 69 into the early 70's using a specific identification system built in large batches. CE engines have no identifiers that specify compression, hose power or application. Meaning one has to tear a CE down and measure things to determine what what you have.
    7 As a thread will tend to stray from the OP's original question I will wander back to it. The probability is that your CE block will will have a casting number ending in 512. Resulting in a 350 point deduction for the casting number, the casting date and stamp pad. Judges then move on to the heads. There is a thread back in the archives that discusses a warranty block that had supporting documents (work orders) showing it was replaced very early. It may have been of a proximate date to the car. I forget the details. That thread relates to the judging consideration you allude to. Scoll down this page to find related threads or search the archives as suggested.
    8 don't forget to give us the casting number and casting date. They are your only hope to minimize block deductions at this point.
    • Mark E.
      • April 1, 1993
      • 4607
      Originally posted by frank hubbard (64183)
      again, i should have been more specific. the 50/5 would have been the power train warranty.
      In this time period, there was no power train warranty. The car overall had a 12 month/ 12k mile warranty, with some exclusions like tires and other wear items.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Frank H.
        • November 17, 2017
        • 44
        #18
        dan, i'll get back to you with the casting number as soon as i can. unfortunately,
        it looks like it's covered by the mounting bracket for the kick down linkage. i see
        a bore scope in my future.
        the casting date as near as i can make out is: E16 8
        thanks again.
        • Mark E.
          • April 1, 1993
          • 4607
          #19
          Factory warranty back then was 12 months/12k miles.
          Correction: I looked at the "Owner Protection Plan" booklets for 1965 Chevrolet and Oldsmobile. They state the new car warranty is 24 months/ 24,000 miles. I think it was increased to 36/36,000 in the 80s(?)
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
            • 15632
            #20
            My 1970 was 12 month or 12K on the entire car, except tires (they had a separate warranty from the manufacturer), and battery (also with a separate warranty). However the powertrain was warrantied for 5 years or 50K. There are 8 exceptions to the 5/50: i.e. clutch, brakes, taxi cab use, etc.
            • Mark E.
              • April 1, 1993
              • 4607
              #21
              Interesting. A 1969 Chevrolet New Car Warranty booklet on-line shows 12 month/12,000 mile warranty but no separate power train warranty.
              Apparently the warranty changed a lot over the years.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Frank H.
                • November 17, 2017
                • 44
                #22
                mark, i've seen the 50/5 warranty referenced in several places and you know if
                you read it on the internet it must be true. not being a chevy guy for very long
                i don't have a clue.
                here's one in the 2nd post.
                https://www.corvetteforum.com/forums...the-1970s.html
                  • 15632
                  #23
                  Trust me. Those of us who know John Z know you can take what he says to the bank.
                  • Frank H.
                    • November 17, 2017
                    • 44
                    #24
                    terrry, that's what i'm beginning to learn. guy's a veritable encyclopedia of chevy
                    knowledge. of course he's not the only one on this forum.
                    • Mark E.
                      • April 1, 1993
                      • 4607
                      #25
                      My reference is a photo of the "1969 Chevrolet New Vehicle Warranty and Owner Protection Plan" booklet. The one page of text describing the warranty is clear: 12 months/12,000 miles. No power train warranty is described.
                      Maybe 1970 is different?
                      We know 1965 is different: 24 months/24,000 miles and no power train warranty.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Mark E.
                        • April 1, 1993
                        • 4607
                        #26
                        I just looked at a "1966 Owner Protection Plan" booklet: 24 months/24,000 miles with no separate power train warranty mentioned (similar to 1965).
                        If someone has a collection of these booklets, it would be interesting to understand how warranty coverage evolved over the years.
                        It surprised me GM reduced the warranty period from two years to one sometime between 1966 and 1969.
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Jack M.
                          • March 1, 1991
                          • 1193
                          #27
                          I'm including a section of the 1967 Warranty info from the Chevrolet Finger-Tip Facts (back of REVISION page):
                          Here's the FULL warranty page in PDF format:
                          1967 Warranty.pdf
                          And a copy of the 1967 Warranty brochure that I found online:
                          • Dan A.
                            • May 31, 1974
                            • 1073
                            #28
                            thanks again.
                            Frank, judges have to deal with this road block on the judging field. If you hold you mouth just right and work an inspection mirror just right, with some persistence, you can get it. You not being on a judging field have the luxury of loosening the 2 bell housing bolts just enough to make the task a little easier.
                            • Frank H.
                              • November 17, 2017
                              • 44
                              #29
                              dan, good idea, i'll give it a shot.
                              • Rocco S.
                                • December 21, 2013
                                • 180
                                #30
                                Here's copies from my 1967 Corvette Warranty Book. This is the book that contains the P-O-P. Build date of my car was late March 1967. It clearly states a longer warranty on most engine related items.
                                ROCCO SCOTELLARO
                                1967 Lynndale Blue/Black Coupe L79, M21, G81 (3.70:1), A31, A82, C60, K66, N11, U69
