67 rear bumper bolts - NCRS Discussion Boards
  • Glenn B.
    • June 4, 2008
    • 76
    Looking to replace my stainless steel bolts in my rear bumper with the correct head making. I have the 5th edition Judging Guide, looks as if RBC, SBC, TR, M, and RBW are acceptable, just checking to see if there as been any changes. Its a January car.
    Glenn
    73 Top Flight Nationals
  • Gary B.
    • February 1, 1997
    • 7066
    Re: 67 rear bumper bolts
    Glen,
    What I've most often seen on original '66s and '67s are RSC headmark bumper bolts. With a small number of TR bolts in certain locations. I'm surprised the JG does not mention RSC.
    Gary
    • Glenn B.
      • June 4, 2008
      • 76
      Sorry Gary,it does have RSC, typo. Had the car for a few years, changing a few things as i get to them, want to have it flight judged as some point.
      • Mark M.
        • October 21, 2008
        • 343
        To add to this , I've seen a number of original 67s rear bumper bolts with SBC on the head and they had no other marks meaning they are a soft bolt. The earliest I remember was an april car. I don't know if anyone has ever repoped this 7/16 bolt.
        • Gary B.
          • February 1, 1997
          • 7066
          I don't know about an SBC repro, but the RSC headmark bumper bolts are repro'd by Richard Fortier. They are spot-on based on my comparison woith originals. To the best on my knowledge no one else repros that headmark in bumper bolt size. One step in Richard's repro process is done by hand and the bolts are therefore, shall we say, not inexpensive.
          Gary
          • Glenn B.
            • June 4, 2008
            • 76
            Everything that I have gotten from Richard Fortier I have been well pleased with.
            • Gary B.
              • February 1, 1997
              • 7066
              Me too.
              Gary
              • Peter M.
                • May 30, 2013
                • 361
                Glenn and Gary,
                When I did my 67 the 122267 bolts were SBC and 122293 bolts were RBW.
                The bumpers had been rechromed at some time but the bolts looked original to me, for what it's worth.
                Kind regards
                • Gary B.
                  • February 1, 1997
                  • 7066
                  Peter,
                  Clearly there were other headmarks used in '67. But RSC's are not uncommon for '66 and '67. The repro bumper bolt kits sold by all the Corvette catalog companies have an inaccurate version of the M headmark bolt, which is why I was excited when Richard started to repro the RSC bumper bolt about 7 or 8 years ago.
                  Gary
                  • Peter M.
                    • May 30, 2013
                    • 361
                    Gary,
                    I agree, I only mentioned the part numbers to identify the different bolt lengths. They could have been any of the head marks you mentioned.
                    I was just saying what I found on my car.
                    Kind regards
                    • Gary B.
                      • February 1, 1997
                      • 7066
                      Peter,
                      Yes, I recall some are 1" and some are 1.5" long..
                      Gary
                      • Gene M.
                        • April 1, 1985
                        • 4233
                        More important than the marking of the grade 2 hardware is the finish on the bolt and nut, and the hex nut size between a very early build and later versions.
                        This was a time of GM finish change as well as an ANSI standard revision on the 7/16” nut hex from 5/8” to 11/16” hex size. Oddly the 7/16” hardware is the only one to have bolt and nut hex differ.
                        • Gary B.
                          • February 1, 1997
                          • 7066
                          Gene,
                          The 5/8" across the flats (ATF) bumper nuts in zinc persisted into the early part of the '67 model year, to be replaced by the 11/16" ATF black phosphate nuts, which were in fact the exact same 11/16" ATF nuts used at four locations on the large, front ,two center bumper braces that were used since '63.
                          Gary
                          • Michael H.
                            • December 1, 1987
                            • 732
                            Glenn,
                            Just FYI rear bumper bolts and braces are only worth 3 points on originality and 3 points on condition for both sides, so that means each side is only worth 1.5 points . So you shouldn't lose any points if you have the wrong bolts especially if you count all the braces, bolts, washers, etc.
                            The front is worth 4 points for originality and 4 points on condition.
                            Mike
                            • Gary B.
                              • February 1, 1997
                              • 7066
                              Mike,
                              I think it will depend on the judge, and the year. As an example, say on a '63 thru '66, if all the bumper nuts on the car are 11/16" across the flats (instead of the correct 5/8" ATF, except for qty=4), what would you do if you were a chassis judge? On the front and rear combined that comes to 26 incorrect nuts. Would you make a note on the judging sheet, but take no deduct? Or take a 1-pt deduct for the front/back combined?
                              Gary
