I have a 67 L79 small block with a 4 speed and positraction I need to replace the worn nylon driven gear. The tank sheet and stamping on the differential case indicate that the gear ratio is 3.55. The speedometer is accurate.
The driven gear that I removed is a 22 tooth green one. The Long Island Corvette catalog says this is for a 3.70 gear ratio and that I should use silver 22 tooth gear and that the green one should not be used with the 3.55 ratio.
The only work done on the rear end was to correct some chattering positraction clutches many years ago.
Which one should I order, Green or Silver?
Thank you,
Randy
Thank you,
Randy
