C4 wheel bolt pattern? - NCRS Discussion Boards
  • Ron B.
    Infrequent User
    • July 31, 1976
    • 20
    Hi
    I have a set 0f front and rear C4 suspensions that I picked up at a swap meet for a special project.. My problem is that the bolt patterns do not match.. Front is 4 3/4" rear is 4 1/2 or metric equiv.. Need years of pattern use so I can order correct wheel bearing /hub assemblies..to match front & rear? Parts catalogs say one hub ass'y fits 84-96?
    Ron
  • Jim L.
    • September 30, 1979
    • 1817
    Re: C4 wheel bolt pattern?
    All C4 wheel bearing assemblies have 4-3/4" bolt circles.
    If the rear suspension you bought has 4-1/2" bolt circle, it's because someone installed the wrong bearing assembly.
      • 43289
      Jim and Ron------
      I agree. No C4 Corvette ever was originally built with a 4-1/2" bolt circle wheel. In fact, if they had been built with a 4-3/4" front and 4-1/2" rear, then the spare tire would not have been usable on the rear wheels. No way would GM ever have done something like that.
