68-69 Tri-Power throttle return spring bracket - NCRS Discussion Boards
  • Chris H.
    • April 1, 2000
    • 837
    Over they years I've noticed some cars have a seperate piece on top of the bracket that the spring hooks into as shown in the photo. Other cars do not have the piece, and hook into a hole in the bracket. The Judging Guide makes no mention of this separate piece. Curious as to what other owners have or have seen. My car is a December '68 L71. Thanks, Chris
  • Rich G.
    • August 31, 2002
    • 1406
    • David L.
      • July 31, 1980
      • 3310
      Re: 68-69 Tri-Power throttle return spring bracket
      Chris,
      The 1969 Corvette AIM (UPC L71, Sheet A6) lists Bracket # 3972626 (formerly Bracket # 3960647 in the Revision Records dated 11-18-68) that attaches to the Pull Back Spring # 3972631 (formerly Spring # 3939748 dated 11-18-68 and then formerly Spring # 3937913. Who knows when the actual change was made on the assembly line.
      The bracket in the drawing, however, is different than in your photo.
      Dave
      • Chuck G.
        • May 31, 1982
        • 2039
        My previous 69 427/400 tripower car had a separate bracket similar to the one in your photo.
        IIRC, it had an extra "foot" to prevent it from rotating.
        • Edward D.
          • October 25, 2014
          • 206
          Chris,
          Is your car A/C? That bracket appears to be p/n 3939750 found in AIM C60 sh C6. Along with a very rare special bracket for the solenoid a throttle return bracket is added as part of the A/C solenoid equipment.
          • Chris H.
            • April 1, 2000
            • 837
            Thanks for the responses all. Edward, L71 so A/C not available.
            • Mark G.
              • January 31, 2007
              • 177
              my July 69 L71 does have that little bracket.
