C2 Convertible - Convertible Door Alignment Block shims installed - Thumbs up! - NCRS Discussion Boards
  • Oliver S.
    • December 1, 1999
    • 343
    A couple of weeks ago I installed the shims - parts of the door alignment block. One per door. What a difference - considerable less rattle and movements of the door gaps when driving over a bump etc..
    As far as I have read they were already available during assembly but only few were actually installed. So if not installed afterwards quite a lot convertibles might miss them and, perhaps, rattle. Cheap fix.
    Oliver
    • 6957
    Re: C2 Convertible - Convertible Door Alignment Block shims installed - Thumbs up!
    Oliver, are you referring to the small metal wedges on the door?
    • Oliver S.
      • December 1, 1999
      • 343
      Yes. I added the shims to the wedges to reduce the gap to their plastic counter parts on the body.
      • Oliver S.
        • December 1, 1999
        • 343
        Here is the pic ...
        Oliver
        • Robert K.
          • June 30, 2001
          • 212
          Good morning Oliver,
          Could you post a wider view pic to show where on the door these are located? I would like to look at mine to see if the shims are present...
          Bob
          • Oliver S.
            • December 1, 1999
            • 343
            Here it is ...
            Oliver
              • 6957
              Thanks for the pic. Ed
              • Robert K.
                • June 30, 2001
                • 212
                Same from me - Thanks Oliver! Now I understand!
                Take care,
