Sand like substance in gas - NCRS Discussion Boards
  • Mike L.
    • September 28, 2016
    • 50
    I removed my Holley carburetor in my 64, 365hp today to get it rebuilt. When emptying the gas from the carburetor I noticed there is a "sand like" substance in the gas that came out. Sounds serious to me, anyone know what this could be?
  • Larry M.
    • January 1, 1992
    • 2700
    Re: Sand like substance in gas
    Deterioration of the carb internal plating due to age/corrosion/ethanol fuel??
    Or your gas station is doing a poor job of storing and filtering your gas for the car.
    Larry
    • Mike L.
      • 50
      Larry
      Thanx Larry
      I hope you are correct with the "deterioration" answer. The underside of the carburetors 4 valves were pretty black. I just purchased the car last September so I don't know when the last rebuild was done on the carb.
      Mike.
        • 15706
        Check to see if the carb has a sintered fuel filter inside the fuel inlet fitting. It could be disintegrating.
        • Mike L.
          • 50
          Thanx Duke, I will check that out today!
