Help -- Trying to install reverse shifter shaft, Muncie 4sp. - NCRS Discussion Boards
  • Wayne M.
    • February 29, 1980
    • 6414
    Read items 4 and 5. The hidden words in the last two lines of item 5 are ...over the "ball and turn until the", and [last line] ... "on the shaft detent plate..."
    Sounds easy but my thumb is not strong enough, or the spring is too strong. What would a "suitable tool" be ?
  • Richard G.
    • July 31, 1984
    • 1715
    Re: Help -- Trying to install reverse shifter shaft, Muncie 4sp.
    Pushing it in with a screwdriver will work. If you have to grind the flutes off a round Philips screw driver and use it.
    That will give you a handle and some support for your hands.
    You can even grind the end concave with a dremel if needed.
    Best of luck
      • May 31, 1974
      • 8364
      i use a very thin feeler gauge. mike
