Rear window run for the door glass - NCRS Discussion Boards
  • Ed P.
    • August 10, 2014
    • 89
    What adhesive is used to install the fabric into the run? and which side or the fabric is on the window side, not the glued side.
    Please
    tank u
    ed
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11364
    Re: Rear window run for the door glass
    Ed,
    Any good quality spray adhesive for automotive interior. 3M or equivalent. Make sure you're not using the reproduction felts as they're too thick. This may help....
    https://www.forums.ncrs.org/showthre...603#post807603
    Download the file: Relining the Rear Window Channels final compr - mod.pdf
    • Mark S.
      • July 31, 1983
      • 664
      3M Super 77 multipurpose adhesive works well. Also if you have NOS channels, you may need to bend them out a bit, as some of them become too tight with the felt applied.
      • Ed P.
        • August 10, 2014
        • 89
        Thank you do you which side is what?
        ed
        • Mark S.
          • July 31, 1983
          • 664
          The fuzzy side goes against the glass and the smooth side is glued to the channel. I belive that this is what you are asking?
          • Ed P.
            • August 10, 2014
            • 89
            Thank you Mark yes that is what i was asking.
            ed
