help with the wires and tubes mounted to the top surround metal reinforcement - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1416
    Guys,
    I'm trying to sort out the wires and vacuum hoses running under the front grill area. Looking at the AIM and what I gathered from the JG it looks like there were harness retaining clips that were riveted there originally. These must have been done prior to assembly of the nose because I can't find this procedure in my AIM which must mean it came to the factory with those clips in place. My car needed the top surround replaced and the new metal reinforcement doesn't have these. In addition, I'm not sure about the location of the horn mounting nuts that are in the new reinforcement bar, and both the AIM and the JG are not very helpful. I've attached a few pics of that area from my car as well as the relevant pic from the AIM. it looks like there were originally three clips there. Can anyone confirm this for me? I do see that there are three holes that are there in the support I'm guessing for the three harness clips to be riveted there. Does anyone have a suggestion on how I can remedy this now that the car is together and painted? Thanks for your help.
    Mike
    • 15634
    Re: help with the wires and tubes mounted to the top surround metal reinforcement
    Just an educated guess here = 1968 or 1969??? I am leaning toward the latter from the looks of the AIM page, but my crystal ball isn't working so good today.
    • Michael L.
      • December 15, 2006
      • 1416
      Yes apologies it is a 69. I managed to find my pre- tear down pics and think I have it figured out. There was only one clip from the factory and it was bolted to the surround support, not riveted. The other holes are for insertion of those plastic clips that are part of the harness and insert into the hole to fasten the harness. The horn mounts appear correct as per my original pics.
