Tonawanda Big Block Assembly Sequence - NCRS Discussion Boards
  • Bill L.
    • April 1, 1985
    • 349
    HI:
    When were the engine assembly date and suffix ID code stamped on a big block engine at Tonawanda?
    Prior to adding the heads or after?
    Thanks in advance for any information you can provide...
    Regards
    Bill
  • Larry M.
    • January 1, 1992
    • 2701
    Re: Tonawanda Big Block Assembly Sequence
    Stamped before heads were installed.
    Larry
    • Bill L.
      • April 1, 1985
      • 349
      Thanks Larry.
      • Dave H.
        • August 17, 2010
        • 47
        Can I make the following assumptions:
        1. Assy date and engine code (the large font stamp) was applied before heads were installed on an assembled, unpainted short block.
        2. Pad is taped over.
        3. Long block plus extras are assembled complete (heads, intake, exhaust, water pump?)
        4. Engine painted.
        5. Tape pad removed.
        6. Engine assy complete (carb, dist, wires, alt?)
        Small blocks at Flint the same?
        • Michael J.
          • January 27, 2009
          • 7166
          Distributor was in, wires, carb, alternator added in St. Louis
          • Gene M.
            • April 1, 1985
            • 4233
            4. Engine painted.
            No, number 1 not same and number 3 depends on model year.
            • John D.
              • June 30, 1991
              • 875
              Were big blocks tested and run at Tonawanda like the small blocks in Flint ? I've never seen any pics. If so did they put plug wires on for testing then take them off prior to shipping ?.
                • 15630
                Yes Tonawanda "hot tested" engines before shipping. Yes they had a set of spark plug wires that were part of the test stand. They were different than the wires we would put on the car and different than those that went on at St Louis or other vehicle assembly plants.
                • Jack M.
                  • March 1, 1991
                  • 1193
                  Here's an GREAT article from 1966 Corvette News... unfortunately, I had to reduce the quality due to file size limitations.
                  You should be able to ZOOM into the pictures... click the link below:
                  1966 Corvette News (Vol-9 #5) - Building 427 Engines.pdf
                  • Joe R.
                    • May 31, 2006
                    • 1822
                    Very cool article Jack! Thanks for posting!!!
                      • 15630
                      [ATTACH]91548[/ATTACH]
                      Good you were able to dig up that story Jack. One needs to remember those details work for 1966, but smaller details may differ from year to year, as Gene mentioned above. One needs to study original examples of their year of interest to verify original details that are applicable to their specific year. In some cases it may be necessary to study specific months, weeks or even days of production to pin down fine details. That's what makes this so much fun.
                      • Bill M.
                        • April 1, 1977
                        • 1386
                        I spent the summer of 1969 working in the Tonawanda Engineering Test Lab running engines on the 200 hour durability test and tearing them down for engineering inspection at the end of the test. (The guy running the test in the article's photo is Ralph. That is the big block test cell.) I did see both big block and small block self-destruct, but it was rare. Fun assignment; coming up on 50 years ago. The highlight of the summer was running L-88s on the test. They ran with headers and exhausted through a huge muffler through the roof of the plant. They made a sweet sound you could hear from outside the plant. All other engines exhausted through a system under the floor and were quiet.
                        • Michael J.
                          • January 27, 2009
                          • 7166
                          That's a great piece of history Jack, thanks!
                          • John D.
                            • June 30, 1991
                            • 875
                            Many years ago as a young GM engineer I wandered into the dynamometer test area at the Tech Center in Warren. Back then you could get into almost any building by flashing your ID card. They were doing a durabilty test on Mark IV where they pumped very low temp coolant through the engine overnight until it was essentially iced up. They then started it up and ran it through a series of high RPM tests to see if it would fail. Very cool stuff.
                            • Ray G.
                              • May 31, 1986
                              • 1189
                              Thank You for the experience and History ... LUV this kind of stuff.
                              I hope you dance
