Current thinking on S/B/C Valve Cover Sealant (RTV) - NCRS Discussion Boards
  • Larry E.
    • 1691
    Doing a little engine redo on a 66 Base Engine(L75). Got a nice set of Valve Covers(Long Island Corvette) and
    thinking the RTV sealer should only be applied between the V.C. and the Cork Gasket. Correct? I assume there
    is no sealer applied between the Gasket to the Head. Correct? What type of sealer should I use? Thanks in advance>
    Larry
    Larry
    LT1 in a 1LE -- One of 134
    • 6948
    Re: Current thinking on S/B/C Valve Cover Sealent(RTV)
    Larry, if your using a aluminum cover I just use a skim coat of 3m yellow weatherstrip adhesive. if you are using tin covers I use peratex right stuff also just a skim coat. the tin covers are a tuff seal sometimes, if you skim coat the both sides of the gasket at the bottom and sides it will help. Oil always seems to leak at the bottom rear corners. Let the sealant set up overnight.
    • Larry E.
      • 1691
      Thanks Ed for the response. My V.C. are the "Tin Type". Took a look at the reviews on the Permatex Right Stuff and found that the
      product is good but>>container/dispenser doesn't work well to get the product out. Don't need a big quantity of it. How do you buy
      yours? I see there is various dispensers. Thanks-Larry
      Larry
        • 15706
        In addition to using a gasket cement to attach the gaskets to the valve covers, I recommend wiping the underside of the gasket with silicone spray lube. This will make the cover easier to remove, and even cork gaskets can usually be removed once or twice before a new gasket is needed. This is probably more important on mechanical lifter engines since the covers need to be removed occasionally for valve clearance checks.
        • Gary B.
          • July 31, 1979
          • 926
          You can buy it in Small caulk tubes (1/2 tubes) for around 10-15 dollars. It's easier to use, more dependable than the pressurized squirt cans.
          Just keep the tip sealed.
          • Jim L.
            • September 30, 1979
            • 1816
            The aerosol dispenser works very well. Using it you can lay down a uniform bead of sealer every time.
            I use Right Stuff to adhere the gasket to the valve cover. I also coat the interior edge and the bottom surface of the cork gasket with Right Stuff just in case there is any porosity in the cork.
            This is certainly not the only method for sealing valve cover gaskets. It is a method with which I have had 100% success.
            Jim
            • Frank D.
              • December 27, 2007
              • 2703
              I use the thicker FelPro cork gaskets with Right Stuff between the gasket and valve cover. FelPro makes two thicknesses.... I spray some PAM outdoor barbecue grill non-stick coating on a fingertip and wipe it along the ridge on the heads. I get a half-dozen remove and install cycles out of the arrangement...
              • Larry E.
                • 1691
                [QUOTE=Jim Lockwood (2750);849890]The aerosol dispenser works very well. Using it you can lay down a uniform bead of sealer every time.
                Thanks to all that has responded>Question For Jim Lockwood> I noticed there are two aerosol cans for the Right Stuff>85224 and 85144. Which one do you use? Also does the can have enough aerosol to empty all of the product or do you end up throwing a good
                portion away?? Thanks--Larry
                Larry
                • Keith B.
                  • September 15, 2014
                  • 1588
                  I always use Permatex 20539 Indian head gasket shellac to glue the gasket onto the valve cover
                  • Mark E.
                    • April 1, 1993
                    • 4598
                    That's old school stuff. I thought it was intended for hose connections and non-porous surfaces.
                    A couple of folks recommended Permatex The Right Stuff. How does it compare to Permatex #2? (Which is what I use for VC gaskets.)
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                    • Keith B.
                      • 1588
                      • Jim L.
                        • 1816
                        I've use the black Right Stuff exclusively.
                        The gray Right Stuff (85144) is a new one on me. I didn't know it existed.
                        I can't answer your question about the aerosol capability. A single can has more than enough for a complete engine build. Typically I don't assemble engines often enough to go back and use up the rest of the previous can. I always start with a fresh can.
                        There is no comparison to Permatex #2. They are totally different substances.
                        Right Stuff seems to be sort of a rubber material, but not like silicone sealers. #2 is just sticky goo and filler.
                        Right Stuff can be applied and the part put back into service immediately*1. With #2, you ought to let it dry.
                        Right Stuff can serve as an adhesive; it sticks tenaciously. #2 .... not so much.
                        Right Stuff is expen$ive. #2.... not so much.
                        Hope this helps,
                        Jim
                        *1 - At Laguna Seca, my bride came in with oil all over the windshield. A valve cover gasket had let go. I cleaned the valve cover, applied Right Stuff and a new gasket, moooshed it back on (technical term), cleaned the windshield, and my bride went back out. No leaks. No problems.
                          • 6948
                          Guys, I have run my own automotive shop for 31 years, over the years sealing science has evolved and The Right stuff is all I use in my shop when the engine does not use gaskets, it has quick set properties which is what I need, most RTV sealants really need 24hrs to fully cure. It can also be used along with gaskets to aid in sealing. Our old school cork and paper gaskets really need help. If you are dealing with a small block aluminum SHP motor where you are pulling the covers for valve adjustment I WOULD NOT PUT ON THE BOTTOM OF GASKET(engine side). when fully set it will need to use a little prying to release.
                          • Larry E.
                            • 1691
                            FWIW>Thanks for all the response. After reading them I still not sure on what to purchase. There are many/many reviews on this
                            product. Many are like the following>
                            1.0 out of 5 starsGreat product, TERRIBLE PACKAGING
                            June 15, 2015Size: Pack of 1Style: 7.5 oz. PowerBead
                            Absolutely awesome product that comes in an absolutely terrible package. Consider it one-time use. Totally ridiculous and wasteful.
                            It seems to many it is a one-time use.(REGUARDLESS OF THE DISPENSER) It comes down to this with many of the sealers/glues(super glue)>
                            THE PRODUCT ENGINEERS ARE DECADES AHEAD OF THE DISPENSING ENGINEERS!!
                            THANKS AGAIN-LARRY
                            Larry
                            • Jim L.
                              • 1816
                              You can always buy Right Stuff, try it and see if it works for you. If it doesn't work out, you've learned what not to use.
                              FWIW.... I read a few of those 1 star reviews. Some of the writers had trouble assembling a coherent sentence using actual nouns and verbs.
                              Jim
