Lighter Element - NCRS Discussion Boards
Lighter Element
  • Deane M.
    • January 2, 2007
    • 143
    Lighter Element
    Like everybody else I am looking for a good source for a Casco 63 Lighter Element for my 68 car. Bought a few off eBay but they don't work.....
    Let me know.
    Thanks.
  • Gary B.
    • February 1, 1997
    • 7064
    Re: Lighter Element
    Deane,
    Were the ones you bought on eBay NOS?
    Gary
    • Deane M.
      • January 2, 2007
      • 143
      Re: Lighter Element
      One was. I also bought ones that were not. The NOS one just didn't work. The others looked perfect but also didn't work. Its the story of my life.......
      • John M.
        • 47
        Re: Lighter Element
        Maybe you should just stop smoking!
          • 6955
          Re: Lighter Element
          Dean are you sure its not just a electric circuit issue, maybe a ground or power problem ? if you have a test light or volt meter you can use the side of the case as the ground and then just touch the center contact in housing, just be sure not to let the leads touch each other, you will blow the fuse.
          • Harry S.
            • July 31, 2002
            • 5342
            Re: Lighter Element
            Tough crowd!
            • Larry M.
              • January 1, 1992
              • 2701
              Re: Lighter Element
              Can't imagine a lighter element not working unless the heating coil is broken into two....or the circuit is bad. Use your Fluke meter (or other multimeter) to check the resistance or continuity of the heating coil.
              I guess it is possible to be trying to use a Casco 63 element inside a lighter housing made for another type element. That could also be an issue. Chevrolet used a few different housings/element combinations over the years in various models of their lineup. Maybe over the years someone changed the original in your car.
              Larry
              • Deane M.
                • January 2, 2007
                • 143
                Re: Lighter Element
                Thanks Ed. I do have power there.
                • Deane M.
                  • January 2, 2007
                  • 143
                  Re: Lighter Element
                  Larry
                  Didn't think of that. Looks correct but......
                  Thanks.
                  • Deane M.
                    • January 2, 2007
                    • 143
                    Re: Lighter Element
                    Originally posted by Harry Sadlock (38513)
                    Tough crowd!
                    Harry, you have to sit at the big table with the guy.....
                    Talk about tough.
                    • Deane M.
                      • January 2, 2007
                      • 143
                      Re: Lighter Element
                      Btw Harry, I did make that call so thanks for the heads up. Also thanks to Dave Strickland. You guys are the best!
                      • Deane M.
                        • January 2, 2007
                        • 143
                        Re: Lighter Element
                        I did! down to just two packs a day now.............
                        • Patrick C.
                          • January 16, 2013
                          • 327
                          Re: Lighter Element
                          Episode 26 might be helpful. I was having problems last month with mine also
                          National Corvette Restorers Society Oklahoma Chapter. Corvette enthusiasts from Oklahoma and surrounding states who join together to celebrate and enjoy the Chevrolet Corvette. The Oklahoma NCRS Chapter members hold regular monthly meetings to share our interest in the Corvette. This is a place to find like minded individuals to support your passion, whether you are driving a brand new Corvette, restoring an old Corvette or just trying to relive a past Corvette experience.
                          Good Luck
                          • Deane M.
                            • January 2, 2007
                            • 143
                            Re: Lighter Element
                            Good Luck
                            Thanks Patrick!
