Had a Big scare from the New '58-'62 JG/TIM - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 660
    I was excited to receive the new '58 to '60 Judging Guide/Technical Information Manual and started to go through it right away. When I got to the mechanical section, I was taken aback by a paragraph that states that Flint blocks can be distinguished from a Tonawanda block by a square plug in the front of the block inboard of the stamp pad. This was the first time that I had heard this as I had been using the old JG/TIM as a restoration guide for over a decade and this was not mentioned previously. So, I went out to the garage and saw that my block has a hex head screw in this position vs. a square plug which gave me a scare as a wrong block is a BIG 350 point deduction. I thought that I had been meticulous in my restoration by ensuring that I had a correct block. Next, I got out the mirror to double-check the casting date which is "L129". According to the new JG/TIM then, I have a Flint block as the Tonawanda blocks had two year numbers. So, my question is: will I receive a point deduction because I have a hex head plug vs. a square head plug? Should I attempt to find a square head plug and replace the hex head one?
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Mike M.
    • May 31, 1974
    • 8400
    Re: Had a Big scare from the New '58-'62 JG/TIM
    PM me your snail mail address and I'll send u the correct plug, on the cuff. mike
    • Keith R.
      • August 31, 2001
      • 660
      Thanks Mike - will do!
      PS. Thanks for all the good instruction at the Dallas Judging Retreat. I appreciate all your sage advice.
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      • Keith R.
        • August 31, 2001
        • 660
        Here are some photos so that it's clear what I am referring to.
        Keith MacRae
        NCRS #36692
        New Mexico Chapter
        1960 290HP FI
        • Michael J.
          • January 27, 2009
          • 7145
          #14 knows his stuff........
          • Brian M.
            • February 1, 1997
            • 1840
            I'd leave that plug where it is. JMHO
            • Mike M.
              • May 31, 1974
              • 8400
              Brian: why? mike
              • Brian M.
                • February 1, 1997
                • 1840
                Why not? It could be opening a can of worms. What kind of deduct is that plug?
                  • 15706
                  I believe that's an oil gallery plug. If the engine was ever rebuilt the original was likely removed for hot tanking and replaced with a new plug with a different head configuration.
                  • Roy S.
                    Past National Judging Chairman
                    • July 31, 1979
                    • 1025
                    I could be all wet here, but I believe the flint blocks had a square head plug when produced, the Tonawanda blocks have no plug!!!! they are if I'm not mistaken not drilled and tapped for this plug. I would assume the deduct would therefore be minor for a hex plug, the important thing is that the block is drilled and tapped.
                    • Dennis C.
                      • June 30, 2002
                      • 884
                      I think this actually brings up an interesting point. The block casing configuration falls under the category of a standard deduction. Therefore, a partial deduction is not a possibility.
                      However, Roy is correct, a Tonawanda block would not have the tapping at all. This was only on Flint blocks. This item is checked to confirm the correct configuration for a Flint block.
                      In my opinion, I would not be looking to take a deduction for the incorrect type of plug. I would just make a note on the judging sheet.
                      Dennis
                      • Keith R.
                        • August 31, 2001
                        • 660
                        PM'd you with my snail mail address Mike. Thanks for your help.
                        Keith MacRae
                        NCRS #36692
                        New Mexico Chapter
                        1960 290HP FI
                        • Keith R.
                          • August 31, 2001
                          • 660
                          So Dennis, are you saying that I may incur a 350 point deduction during judging because the case configuration is not correct?
                          Dennis
                          Keith MacRae
                          NCRS #36692
                          New Mexico Chapter
                          1960 290HP FI
                          • Don H.
                            Moderator
                            • June 16, 2009
                            • 2269
                            I think what Dennis is saying is he would take no deduction no matter what plug he saw in the hole. Just so long as there is a hole.
                            He would write a note saying "Plug S/B square, not hex" in the notes box for that scoring line. Your case configuration IS typical of Flint production.
                            Only your plug is non-typical.
                            • Keith R.
                              • August 31, 2001
                              • 660
                              Thanks Don. I reread his comments and I agree that is what he is saying.
                              Keith MacRae
                              NCRS #36692
                              New Mexico Chapter
                              1960 290HP FI
