Williams/Hinckley timing paper questions - NCRS Discussion Boards
    • 15706
    Re: Williams/Hinckley timing paper questions
    The first recommended specs were based on dial indicator diagrams I took on a new GM LT-1 cam purchased from a Chevrolet dealer back in the seventies, and I also measured and characterized rocker ratio behavior at that time that are reported in all versions of the paper.
    The revised specs are based on the actual drawing lobe lift data, inches to five decimal places, every CAM degree. Then I built an Excel program to compute the velocity, acceleration, and jerk. This allowed me to define the tops of the clearance ramps with a much higher degree of accuracy. This is why I say to only pay attention to the 09/08 revision.
    Previous revisions are OBSOLETE!!! IGNORE THEM!I have contacted Web sites that still have old versions with a e-copy of the 09/08 revision with a request to update and was ignored by all. This is a real problem with the Web. Once something is posted it's very difficult to remove even if the information is superseded or proves to be inaccurate.
    • Gary S.
      • July 31, 1992
      • 1633
      Thank you for the follow up. I did NOT follow the old numbers, as I mentioned in the previous question, figuring that the new information was more accurate. I was just curious.
      As you stated, once something is on the internet it becomes exceedingly difficult to get rid of it. Of course, various celebrities and politicians have found this to be not to their liking.
      Once again, Duke, I do thank you.
      Gary
