1967 L79 M20 rear end - NCRS Discussion Boards
  • Gary H.
    • September 18, 2018
    • 69
    I just got my car back from volunteering for the NCRS Judges Training Retreat in Grapevine, TX. Car's never been officially judged yet. One of the judge trainers (Pat. Should have noted last name.) said my differential might not be original or correct. I finally found a pic. I think I have a posi 3.70 June 29 1966. Can I get a second opinion? Thanks.
    I'm a little confused by the single "6" to the right on the image.
    Last edited by Gary H.; March 18, 2019, 06:39 AM. Reason: confused by the single "6"
    gary...
    1967
    Convertible, L79 327/350hp, M20, Marlboro Maroon (sort of) / Saddle
  • Timothy B.
    • April 30, 1983
    • 5196
    Re: 1967 L79 M20 reared
    Gary,
    What's the build date on the trim tag under the dash?
    • Gary H.
      • 69
      26 June, 1967
      VIN: 194677S122643
      gary...
      1967
        • 6950
        Gary, you have the date correct June 29, 66, As far as being original to your car, its not likely, but as they say never say never, its date stamp make its likely for a very late 66 or a early 67.
        • Leif A.
          • August 31, 1997
          • 3644
          And, didn't all L79 in 1967 come with M21 not M20??
          Leif
          • Timothy B.
            • April 30, 1983
            • 5196
            Originally posted by Gary Hardy (65191)
            26 June, 1967
            VIN: 194677S122643
            Stamped K 26 ?
            • Gary S.
              Super Moderator
              • February 1, 1984
              • 460
              I thought the same, but not all 67 L79's had M21. It depended on the rearend it seems. My very original 67 L79 has a 3:36 rear and M20 and that is on the tank sticker too. I think if you have a 3:55 and lower you got an M21. And higher got you an M20. I am sure someone will correct if that is not right.
              Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
              • Gary B.
                • February 1, 1997
                • 7053
                Edward,
                Why do you say "not likely"? The C2 Registry birthday calculator lists an estimated birthday of July 7 for Gary's VIN. Yes, the rear diff date of June 29 is close, but perfectly possible.
                Gary
                • Gary S.
                  Super Moderator
                  • February 1, 1984
                  • 460
                  Can you read the casting date on the side of the case? If cast in 67 it would seem you have a character missing in the assembly stamping is all.
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11334
                    Gary, When I zoom in on the diff photo I seem to see traces of a very lightly hit "7" after the 6, which would be "67". The year should be 2 digits. It looks like the diff was painted so it may be easier to see if you clean the paint away in that area.
                    Is your car body AO Smith built? K26?, as Timothy is hinting to? If so that may be why the build date on the Trim Tag is off from the estimated calendar build date, and 3 days earlier than the diff build date. June was the last month for AO Smith builds as all bodies in July were built in St Louis.
                    Also, the birthday calendar(estimated) shows your vin as July 7, 1967 build, so a June 29, 1967 differential seems legit to me.
                    Rich
                    PS Edit.... Gary Seymour ...... good idea to check the cast date
                    • Leif A.
                      • August 31, 1997
                      • 3644
                      A picture of the housing in my June 14, 1967 built car for reference.
                      Leif
                        • 15706
                        Only the close-ratio four-speed was available for the '65 L-79, and the standard axle ratio was 3.70. For '66-'68 you could also order L-79 with a wide-ratio four speed and the standard axle was 3.36.
                        Each trans also offered optional ratios. Details are in the AMA specs and NCRS Spec Guides that show all available drive train combinations for the various model years.
                        • James G.
                          • May 31, 1976
                          • 1556
                          Rich
                          I AGREE. And just maybe, the operator did not clock the stamp correctly.
                          • Joe R.
                            • July 31, 1976
                            • 4551
                            Gary, Your rear end is just as original as any 67 produced by GM at St. Louis..
                            Parts were not sitting in a row by serial number or production waiting for the next car to come down the line.
                            Production workers crammed the first one they could get in their hands to keep production going and the checks coming.
                            JR
                            • Tim G.
                              • March 1, 1990
                              • 1389
                              Gary, I think the "7" is either stamped lightly or just missing. Your tank sticker calls out a 3.7 rear end, so that further verifies that the rear end in your car is the original piece. If you have the warranty plate, the assembly date of your differential should match the date on the warranty plate.
                              Your car just keeps getting better and better. It was good to see you and your car at the judging retreat.
