1954 valve stems - NCRS Discussion Boards
1954 valve stems
  • Bob W.
    • July 31, 2002
    • 55
    1954 valve stems
    Anyone know where I can buy the correct valve stems for the 54 steel wheels.I bought some from ecklers they were to small for the valve stem whole. Thanks Bob W
    • 43258
    Re: 1954 valve stems
    Bob------
    What's the size of the valve stem holes in your wheels?
    • David B.
      • March 1, 1980
      • 689
      Valve stem assembly 273232 had installed length of 1.25" less cap. designed for Straight snap-in type .625 Dia. rim hole. Very commonly used on Corv. Pass cars, trucks etc.etc.
      • Bob W.
        • July 31, 2002
        • 55
        The size of the hole that are in the rims 5/8 of an inch the other rims I have are 1/2 in but they are not correct for the 54
          • 43258
          Bob------
          The GM #273232 that Bob mentions is the correct valve stem but they are discontinued and you'll probably have a difficult time locating any. I think the Patch Boy #TR415 is about as close as you'll come (www.patchboy.com).
