56 57 Door Lock Control? - NCRS Discussion Boards
  • Mark S.
    • July 31, 1983
    • 663
    Pictured is a door lock control that I have labeled for a 56 or 57 Corvette. I notice from the parts vendors catalogs that there is a different door lock control for the 56/57, 58, 59/61 and 62. I also see that some vendors list the same door lock control for 56/57 and 63-66. According to my parts book the 56/57 door lock control is listed as part # 3735227 (LH) and # 3735228 (RH). I assume that the same control is used for both sides. Can someone please verify that this is the correct control for the 56/57; and can it also be used for the 63 to 66 models? Also, for my learning curve is there a picture of the four different versions used from 56 to 62? Thanks! Mark
  • Mike E.
    • February 28, 1975
    • 5141
    Re: 56 57 Door Lock Control?
    Mark,
    I know that a significant part of the difference is the length of the shaft because of the changes in door panel thickness. Beyond that, ??
    • Mark S.
      • July 31, 1983
      • 663
      Thank you very much Mike! I am hoping that someone can give us additional information.
      • Rod K.
        • 443
        Mark, looks like my Nov '56 built car lock controls. AIM shows p/n 3723507, Control Assy, only one p/n so indicates same for both L & R. Shaft length is approx 0.855 from mounting face to end of shaft. Hope this provides some helpful info.
        • Mark S.
          • July 31, 1983
          • 663
          Thanks Rod! This helps put some of the puzzle together. Sincerely, Mark
