Clutch pivot stud - NCRS Discussion Boards
Clutch pivot stud
  • Jerry M.
    • March 1, 1978
    • 147
    Clutch pivot stud
    The clutch pivot ball stud that mounts to the frame on my '62 is slightly worn. Presuming that it would be best to replace it, would it be better to replace just the ball stud or to replace the bracket assembly with the ball stud already attached. Both ways are available in the aftermarket.
    Jerry
    • 43211
    Re: Clutch pivot stud
    Jerry
    Jerry-----
    Either way, I think it's a bit of a hassle. The bracket is welded to the frame. So, if you replace the complete bracket assembly you will have to cut the existing one from the frame, then weld-on the new one.
    On the other hand, I believe that the original ball studs were only supplied as part of the bracket assembly. I think they are more-or-less permanently attached to the bracket. So, I don't know how replacements would be attached.
    • Jim D.
      • 2883
      The original stud is pressed into the bracket. It's been many years since I replaced the one on my 60 but if I remember correctly, I simply hit the back side of the stud with a grinder and knocked it out. Put the new one in and tack welded it in place.
      • Frank D.
        • December 27, 2007
        • 2703
        On my 61 a friend and I replaced the ball stud -- mine was worn so badly it actually cut a groove in the bellcrank tube....which I also replaced.
        • Jerry M.
          • March 1, 1978
          • 147
          Thanks for the input guys. It's good to hear that somebody has replaced just the ball stud successfully and has withstood the test of time.
          • Frank D.
            • December 27, 2007
            • 2703
            My repair lasted 5 years until I sold the car.
            It gets me how some owners are so quick to jump on the "gorilla spring" and think that's the source of a gritty or hard-to-operate clutch and if they spent some time examining all the pivot points, adjustments and angles they might just find they have other problems that are the cause....
