1967 427 Automatic Trans Flexplate and Starter Combination - NCRS Discussion Boards
  • Tim S.
    • March 1, 1989
    • 124
    What is the correct flywheel (flexplate) diameter and number teeth for a 67 427 with Auto trans?
    Is there a part number? Is the 117365 the correct starter, without aluminum nose, for the required flexplate?
    If not what is the correct starter number and configuration/
    Thank You
    • 43290
    Re: 1967 427 Automatic Trans Flexplate and Starter Combination
    Thank You
    Tim------
    All 1967 Corvettes with 427 except L-88 used 14", 168 tooth flywheels or flexplates. The original part number for the 427 with Powerglide flexplate was GM #3899668.
    GM #1117365 starter was used for all Corvette 427 applications except L-88. The 1117365 has a cast iron nose.
    • Tim S.
      • March 1, 1989
      • 124
      Thanks as usual Joe
