I have a few separate issues that are causing me problems.
I am doing a full restoration on a 1967 big block and prior to taking the car apart I made sure that everything was working correctly. This is a former Duntov car and has been through many many operations checks.
1. The low beam headlights will not come on. I have tried two different highbeam switches and I get the same affect. I do have both sides high beams functioning correctly, but I do not have low beam lights at all. The light switch pull works. The parking lights come on at the first notch, but when I pull the switch to the next level the parking lamps extinguish as they should and the headlights simply don’t come on. If I hit the highbeam switch the highbeams come on but no low beams.
2. The right blinker is not functioning. Left works fine. However, I do have hazard flashers and I do you have brake lights. I did change the turn signal switch prior to restoring the car. It was functioning properly when I took the steering column out. When the headlights are on the on position and I put my foot on the break the inside right light tail light goes out. The right inner also seems like it is dull compared to the other right light. I did change the bulb and got the same reactions.
3. I have power to the radio but when I turn it on I get nothing. I also can’t get the light to work on the radio.
You are all much smarter on this than I am. Any help will be appreciated. All the wiring harnesses are original.
