rubber nut for voltage regulator? c2 - NCRS Discussion Boards
  • John P.
    • August 31, 2002
    • 215
    wondering about source for accurate repro of these rubber nuts for my 1965 convertible. Previous from Long Island Corvette , purchased 2-3 years ago, are too small and do not seat tightly in wheel well wall holes, which appear original.
  • Stephen L.
    • May 31, 1984
    • 3156
    Re: rubber nut for voltage regulator? c2
    Try Richard Fortier. He advertises in the DRIVELINE. He has a huge selection of original fasteners.....
    • Dick W.
      • 10483
      Look in the Auveco or McMaster Carr catalogs. They are called well nuts
      Dick Whittington
      • Leif A.
        • August 31, 1997
        • 3627
        John,
        It's quite possible that the holes are original but wallowed out a bit. You might try cutting some electrical tape to the width of the rubber and wrap them one time to make them snug...that's all you need is snug not real tight. The three screws will not allow the V/R to go anywhere. Just a thought. BTW, I have used the LIC nuts in the past with no issues.
        Leif
        • Garth T.
          • January 24, 2018
          • 20
          I thought mine from Paragon were too small in diameter as well but as I tightened them down they snugged up nicely. You might try that.
          • John P.
            • August 31, 2002
            • 215
            Well I did the electrical tape wrap. Not great for my tastes, but adequate. The LIC parts were quite a bit smaller than originals.
            • Jeffrey S.
              • May 31, 1988
              • 1882
              John,
              Well nuts are a common hardware store item (ACE for one). I can't say that they are the same as the VR on a C2 but I do know that they are the same as the original fender louver trim well juts on my '69. Can't hurt to have a look.
              Jeff
              • Dick W.
                • 10483
                Originally posted by Jeffrey Salz (13182)
                John,
                Jeff
                I can't remember the thread size but you may have to tap the threads to either coarse or fine, poor memory prevailing
                Dick Whittington
