The 77 here has a washer function switch that is not working. On a 77, there is a piece of trim just behind this switch, and over the tilt mechanism, that might give me a good look at the switch without having to disassemble the column.
See photo below. The tilt lever is the one on the upper left, the washer/wiper/turn is the lower right.
Is there a way to remove this piece of trim without breaking it? I have seen pictures of it removed, but nothing states how to do it correctly. I will be getting a 7/32 wrench to unscrew the tilt lever first.
And advice you have is appreciated.
Patrick
Patrick
