TIM&JG ; fastener finishes - NCRS Discussion Boards
  • Richard K.
    • April 1, 1988
    • 207
    In the TIM&JG for 68-69 I've come across sentences like this: "It is held by a black-plated hex head bolt, split ring lock-washer, and large thick flat washer". Should it be assumed that the washers are also, black-plated, just as the bolt is? Are all "stacks" of fasteners plated with the same material? Are washers always zinc or cadmium plated?
    Rich K.
  • Gary B.
    • July 31, 1979
    • 926
    Re: TIM&JG ; fastener finishes
    When the sentence is worded that way, yes all are black-plated. Either black phosphate or black oxide.
    Often, lock washers are a natural, dark finish from heat treating, and the flat washers are natural. We tried to identify those by stating that.
    Gary Bosselman
    • Gary B.
      • February 1, 1997
      • 7070
      Originally posted by Gary Bosselman (2575)
      Often, lock washers are a natural, dark finish from heat treating...
      Gary Bosselman
      Yes, it's pretty impressive how dark some lock washers can be from heat treating, e.g., the GM# 103328 lock washer used at bumper attachment locations from '65 thru years onward. They are similar in hue to Black Phosphate-treated parts. But they are not Bl-Phos treated. They are "natural", but heat treated to a relatively high hardness.
      Gary
